vcExpressionProperty
A property that holds an expression, that is evaluated to retrieve a value.
Parent: vcProperty
Children: vcBoolExpressionProperty, vcIntExpressionProperty, vcMatrixExpressionProperty, vcPropertyExpressionProperty, vcRealExpressionProperty, vcStringExpressionProperty, ... (see more)
vcVectorExpressionProperty
Referenced by: vcBufferProductsStatement.BreakConditionProperty, vcChangeProductTypeStatement.RetainVisitCountProperty, vcConstructStatement.AssemblyTimeProperty, vcExpressionProductFilter.Expression, ... (see more)
vcFindFlowStepStatement.LoopingSearch
vcFindFlowStepStatement.ReturnStepOffset
vcFindFlowStepStatement.SkipOptionalSteps
vcGetProductsStatement.MaxCountProperty
vcMoveJointStatement.MotionTimeProperty
vcMoveJointStatement.TargetValueProperty
vcProcessDelayStatement.ExpressionProperty
vcProcessSetPropertyStatement.ValueExpression
vcProcessSwitchCaseStatement.Condition
vcProductPropertyFilter.ComparisonValue
vcProductPropertyFilter.TargetProperty
vcRunRobotRoutineStatement.RoutineNameProperty
vcSelectProductsStatement.MaxCountProperty
vcSendSignalStatement.ValueProperty
vcSetNextFlowStepStatement.ForceExactFlowStepProperty
vcSetNextFlowStepStatement.ForceExactProcessGroupProperty
vcSetNextFlowStepStatement.RetainVisitCountProperty
vcSetProductVisitStateStatement.VisitCountProperty
vcSetPropertyStatement.Value
vcSpecificProductFilter.ProductVariableName
vcSwitchCaseStatement.Condition
vcSwitchFeature.Choice
vcWorkStatement.ProcessTimeProperty
CalculatedValueRealRGets the calculated value of an expression.
TypeError: When type conversion is not supported.
ErrorMessageStringRGets the error message that is caused after evaluating expression.
IsConstantBooleanRGets a value which defines whether the expression value is constant (i.e. it does not depend on any variables or random number input).
IsDeterministicBooleanRGets a value which defines whether the expression value is deterministic (i.e. it does not depend on random number input).
ValueStringRWGets or sets the property value.
waitForobjectString OR None value,
waitForNotobjectString OR None value,
